Ummmm...
Can you point a link at the fuel allowance for diesels?
The rules say:6.5.1 - 90 litres maximum on board whatever the outside ambient temperature and atmospheric pressure.
Diesels can run up to 5.5 L forced induction (instead of the 4.0 L limit for gassers)
Diesels run intake restricters at 39.9mm (up from 32.4 mm for gassers)
Diesels run up to 2.94 bar (at 5.5 L displacement compared to a max 1.5 bar manifold pressure for gassers)
If the weather is particularly warm, then I suppose the diesel crowd has a small advantage since diesel fuel does not expand as much in relation to temperature, so 90L of fuel will have an even greater energy content (along with added weight).
Now this is interesting... Sign me up for a closed car, please...
14.1.9 – Temperature inside the cockpit (closed car) :
The ambient temperature around the driver must not be higher than 30°C (86°F) whatever the temperature on the outside when the car is in motion. After a stop, the temperature must go back down to this value in 5 minutes maximum. An efficient air conditioning system comprising a compressor, a condenser, a pressure reducer and an evaporator is compulsory for the closed cars. It must be described on the homologation form and approved by the ACO.
