Help!! Weird Oil Leak Aghhh
		:cry: :study: :scratch: :banghead: I have an oil leak somewhere and am having problems finding it.It is entirely on the passanger side of the car. I have replaced the valve cover gasket and the cas O ring and 3m yellow stuff(ed) everything and ran in and I KNOW FOR A FACT that it is not lekaing form there ( valve cover or cas-o) but whenever I stop I can smell oil BAD ( I CHOKE ON IT, BAD) so i have only a couple of options left to me and no the coils do not have the bottom bolt in it. no it is not the oil filter ( no double gasket ) the oil on the dipstick drops 4mm or so every 100 miles or so,that eliminates it being anything other that engine oil,
1) oil pan gasket which i did not replce as I said i was going to in a previous post never replaced the oil pump found out it was a bad sensor ( i have a new one now.
2) head gasket ( but it is not leaking radiator fluid) 3) rear main seal ( but how is it getting by the ac hoses area)was repalced last year when I did the clutch
4) front seal
5) I have a crack in the block that I cannot find on the passanger side of the motor
6) ?????????? Something not mentioned here
HELP I just got a new job and I need this car to be running perfect and it is except for this oil leak.
thaks everyone, me and rory are stumped
rich
