Does anyone have any advice for fixing the camshafts in position while you undo the sprocket bolts? I've discovered that my cam seals are leaking, need to undo the bolts but my adjustable wrench isn't up to the job; I'm not convinced that a nice big wrench ($30 from Sears!!) will do the job either. Trying to think of all sorts of elaborate ways I could pin the whole thing in position, but if anyone knows of a better way...
btw, I'm not planning on taking all the covers off the timing belt area, just the top one, as I reckon by clamping the belt to one sprocket, taking the other off, and then vice versa, I can match the sprockets against paint marks without having to do the whole go to TDC then rotate 20 times palava (and save around 2 days work). Has anyone tried this?
