Lust with me - 2006 Pagani Zonda Roadster F
		Not too shabby...
http://www.supercars.net/PicFetch?pi...roadster-1.jpg
http://www.tuningnews.net/news/06022...dster-f-10.jpg
http://www.tuningnews.net/news/06022...dster-f-11.jpg
			 engine Mercedes Benz M180 V12 w/Pagani Intake, Exhaust, Management Systems
 position Mid-Longitudinal
 aspiration Natural
 valvetrain DOHC, 4 Valves per Cyl
 displacement 7291 cc / 444.9 cu in
 bore 91.5 mm / 3.6 in
 stroke 92.4 mm / 3.64 in
 power 484.7 kw / 650 bhp @ 6200 rpm
 torque 1057.54 nm / 780 ft lbs @ 4000 rpm
 redline 7000
 drive wheels RWD w/Traction Control, Self Locking Differential
 body / frame Carbon Fibre Monocoque with Aluminum Sub-Frames, Carbon Fibre Roll Bar
 front brakes Carbon-Ceramic Discs w/6-Pot Calipers, Hydraulic Assist, ABS
 f brake size 385 mm / 15.2 in
 rear brakes Carbon-Ceramic Discs w/4-Pot Calipers, Hydraulic Assist, ABS
 r brake size 385 mm / 15.2 in
 front tire size 225/35x19 Michelin Pilot Sport 2
 rear tire size 335/30x20 Michelin Pilot Sport 2
 steering TRW Rack & Pinion w/Power Assist
 f suspension Alunimum Alloy A-Arms w/Pull-Rod Springs, Olhins Adjustable Dampers, Anti-Roll Bar
 r suspension Alunimum Alloy A-Arms w/Pull-Rod Springs, Olhins Adjustable Dampers, Anti-Roll Bar
 wheelbase 2730 mm / 107.5 in
 length 4435 mm / 174.6 in
 width 2055 mm / 80.9 in
 height 1141 mm / 44.9 in
 transmission 6-Speed Manual w/Twin Plate Clutch
