It worked!
		Normally I don't hold to much faith in the repair in a bottle stuff at the autoparts stores.  However, I decided to try something to fix the slipping tranny in my Nissan as I'm planning on selling it.
I went to O'Reillys and picked up a bottle that claimed to fix slipping trannys.  It was a PITA too as I had to siphon off 12 oz. of ATF to add the 12 oz. of additive.  It did nothing.
Since it was the cheap bottle ($3) I decided to go for a more expensive option.  ($9)  I picked up a bottle of Lucas Transmission fix.
http://www.hardwarestore.com/media/p...4_front200.jpg
The weird thing is it said to just add it to the existing fluid without any need to drain an equal amount of ATF out.  It's 24 oz! I did and let it drain down the tranny dipstick hole.
WOW!!!  The tranny doesn't slip and it has more pep than before.  If any of you have an OTM with a slipping automatic tranny, I can highly recommend this stuff!
Bonus: I also found a loose vacuum line which I think was the cause of it's interminute stalling at idle.
Now, with the exception of a minor oil leak, the truck is mechanically sound.
		Hey, hey!! Now you can keep it!!
