BoostedNB's Turbo Miata part out
Well I have decided to part out of the car. I have listed most of the items on the car, so if you have any questions or anything just ask. And remember that these parts have less than two thousand miles on them. I need to sell some of the big items first so I can pay the loan off on the car. Thanks again.
Engine:
Complete Flyin Miata built long block including:
FM Lightened Knife edged and Balanced Crank
Carrillo H Beam Rods
ARP Lower end studs
FM Billet Main Crank Girdle
Weiseco 9.1 Compression pistons
ARP Head bolts
Oil pump
Multi angle valve job
Port and polished headwork
Unshrowded valves and combustion chamber lip
polished combustion chamber
1mm over on intake and exhaust valves
FM valve springs and retainers
FM adjustable cam gear $6500.00
FM aluminum radiator $250.00
Rolling 99 Miata body with perfect paint and perfect interior Tranny
Rear end included top in good shape Everything works
$4000.00
MoTeC M4 stand alone EMS
Custom wiring harness built by Tony Palo
All fire resistant heat shrink $2750.00
Custom built tubular Stainless turbo manifold
Full Race spec garret gt30R
All hard lines from radiator to turbo for coolant feed
and return.
Hard lines for oil feed and return
Vishnu Fuel Rail
Walboro intank unit
1000cc injectors TIAL 44mm Wastegate
TIAL 50mm blow off valve
Custom 3 in downpipe
Custom wastegate dump tube (to atmosphere)
Custom 3 in full exhast with Apexi Muffler
Custom 2 1/2 in intercooler piping
Precision 24in x 12in x 3 in Intercooler core with
custom endtanks $5500.00
FM Flywheel $300.00
FM Clutch Line $15.00
Interior:
Dual A pillar guage pod
GReddy Trust boost guage
GReddy Trust Exhaust Gas Temp guage $150.00
Sparco Ring Suede steering wheel
Bobby archer miata steering whee quick release $250.00
Sparco Carbon shift knob $20.00
Sparco Carbon pedals $20.00
Sparco Fire Extinguisher $40.00
Sparco Roadster Seats
With sparco seat brackets and
custom floor mounts $750.00
Custom LED shift light $30.00
Clifford Alarm with proximity sensors $100.00
Suspension and Brakes:
Tein Flex coilovers $1000.00
Custom tranny brace $50.00
Racing beat rear stabalizer brace $30.00
Hard Dog Hard Core Double Diagonal Roll Bar $350.00
FM Wilwood 4 piston caliper 4 wheel 2pc rotor big
brake kit, with hard lines. $1100.00
Skunk 2 Titanium lug nuts $50.00
Spotless 16 in x 7.5 in SSR Competition wheels
215 40 16 Goodyear directional tires $1300.00
Garage Vary Urethane lip $90.00
