Today I was leaving the Mall & I noticed the oil pressure was really low, around 15 on the gauge at idle, normally it sits around 30 at idle & goes up with the throddle.
I checked the oil level & everything was fine, no leaks or anything.
The pressure finally went back up to around 30 idling at stoplights, but still that does seem low.
Searching around I stumbled on this thread:
http://forums.dfwmiata.com/showthrea...light=pressure
I just changed the oil last weekend & grabbed a Fram because it was all they had in stock that wasnt rediculously expensive.
The pressure has been fine untill today, & apears to be back to normal, or close to it.
Do you think this could be the problem?? If so is there a way to change just the filter without having to buy all new Mobile 1?
