Popping out switch blanks
		This just sounds so easy, but either I'm missing something, or there's some engineer sitting in a corner laughing himself to death over his diabolical one-way design for keeping the dash switches in place over those RR tracks on Ave N (plano).... :rolleyes:
I'm trying to get one of the switch blanks out of my M1 (97) so I can put the defroster switch in.
  1)  all I can find on the web says to reach around from behind. But on my '97, there's a metal plate that prevents you from actually reaching the backs of the switches. Now if my fingers had 4 segments and were about 18" long, I might be able to do it. -- How do you get these blanks out???
  2) Best I can tell, the correct blank to remove is the leftmost blank; the one nearest the driver door. Can anyone confirm this for the '97?
Thanks!!
		Another challenge now....
				Originally Posted by
rold5
			However, even though the blanks are 'keyed' to accept the appropriate plugs, I think they could be moved easily enough. I plan to try. I want my defrost switch where I can see it better.
 They move very easily.
It works! - I metered it to check because there is no visible light on the dash.
That's because my KG Works instrument panel (http://rspeed.net/product_info.php?c...oducts_id=3116) doesn't have a cutout for the defroster light! The KG panel is beautiful, but....anyone ever try to either relocate the defroster light, or modify one of these to show the defrost light?
