Originally Posted by
trackdog
Add 1/4 of the bottle which is about 2 ounces or so to the oil at each oil change. We have added this to several noisy Miata lifters with excellent results. The thicker oil gets into the lifters and slows down the pressure lose. Seriously, this works.
What is happening is the tiny check valve in the lifters are worn out and not holding the oil in. This will not hurt the engine, but it will be down on performance. I would not go and replace the lifters, but if you have to do any head work then at that time replace them. Aftermarket lifters are around $15-20 each where the dealer is something like $65 each.
