Like the title says, I am heaterless right now. Just put a new thermostat on hoping that would fix the problem, but no. A coolant flush is coming Monday, but I dont know if that will help. The car is a 2000. Thanks
Any coolant leaks in the engine bay?
Check to make sure your heater hose hasn't busted... it'll be right by the firewall.
Is the car getting hot (temp gauge)? Is the top radiator hose getting hot? Do you smell antifreeze in the car or under the hood?
When you adjust the temp control from cool to hot do you hear anything moving in the dash???
I think I found it, the cable that moves the heater door open and shut had slid off of the rod of the heater door. When I turn the knob, the cable moves but the door doesnt. I reattached it, and turned the knob a couple times and the cable promptly slid off again. This was because the clamp holding the cable in place was loose. The pic below shows whats going on down there. Problem solved. Thank You guys.
http://www.miata.net/garage/images/cold.jpg
