I have my fans wire in parallel and since I decided to use the 1.8 waterneck for my 1.8 swap, I took the wire from the temp sensor and ran it to a switch in the dash then to ground to complete the ground circuit. Today the fans decided to quit working and almost overheated on me! I checked all the connection and the light on the rocker switch comes on showing a completed circuit and all the fuses are good.:confused: There is no way the coolant fan motor is toast cause it is practicaly brand new. Is there a relay the fans run through that I should check? I'm lost after all that!::Rant::
