$50.00 takes it
$50.00 takes it
Selling your used underwear??
ding ding ding ...we have a weiner it's black
By NB... do you mean that it won't fit an NA?
(I put the cockpit brace in if that helps)
Price dropped to $49.00 because Sammm is the competition..................
price war on windblockers::Banana::
Does it include the black weiner? ::BaHump::
You want to put that under your car instead of these?
The cockpit brace hurts. I have an NB windblocker in my '96 - but it's in the spot where the cockpit brace USED to be. It more or less follows the angle of the bulkhead behind the seats, and it mounts to the side panels with 2 screws on each side - one of them in an exisitng hole.
I've seen photos of a car with the windblocker in front of the brace, but I'm sure it would interfere with my seat position. As I said, the blocker mounts with a total of 4 screws, so you might be able to figure out an alternative that would let you have both.
I fabricated a bracket that will let you use the windblocker and the cockpit brace together. I've had it on my 2000 since 2000 ;-) works like a champ Also you don't loose any leg room, your seat will go back just as far. You might loose about half an inch of recline though.
The only tool you will need is a 2 wrenchs and a dremel.
will it fit a 96 mx5 if so do you still have it would be interested in taking it off of your hands
I still have it but I don't know if it will fit your car....
