Originally Posted by
Titus
			This is what I found:
According to the Maintenance Schedule, "inspect, with repair, clean, adjust, or replace if necessary" includes: drive belts (tension), engine oil, engine oil filter, air filter, spark plugs, cooling system, fuel lines and hoses, idle speed, brake lines/hoses/connections, brake and cluch fluid level, disk brakes, tire inflation pressure and tire wear, steering operation and linkages, power steering fluid level, front suspension ball joints, drive shaft dust boots, bolts and nuts on chassis and body, exhaust system heat shields, all locks and hinges, air conditioning refrigerant and compressor, drive belts (tension), manual transmission oil, rear differential oil, drive shaft boots and washer fluid level.
