So, for the last week or so, I've had this odd shimmy in the front end of the car. It only turns up under braking from 50mph+, and if I hold the brakes steady, say from 70mph to 30mph, it goes away under about 45mph. Doesn't matter if I brake lightly or at the threshold, it still shows up, but only in that speed range (50mph+).
My first thought was that it was a warped rotor, but it only happens above 50mph, and I can roll the car along at 5mph or so and lightly apply the brakes, and I don't get the "pulsing" feeling that usually accompanies a warped rotor.
I've got an old set of well worn stock rotors that I can remount to see if it is a warped rotor, but before I did that I wanted to see if any of you might be able to think of something else that could be causing the problem.
Any ideas? :scratch:
