Not when I stop but I can hear a light squeal when I am driving against a wall. I took the brakes apart tonight and everything looked good. Good pad still left, all clips in their place. The only issue was that the inside pad had slightly uneven wear. The bottom was slightly more worn than the top. Side to side everything looked even though. My main thought was dry slider pins. Should lubing my slider pins solve this problem? Should I write off this set of pads now? Thanks.
P.S. Jrj512 any comments you have about lubing slider pins can be omitted from this thread. TIA ::BaHump::
