Originally Posted by
Mouglie
			In order to replace the oil pump seal i had to remove the A/C compressor and its belt plus the alternator belt. Then remove ignition coils, spark plugs with wires, valve cover, timing belt, remove the alternator, disconnect radiator pipes and remove the oil pan. I've done most of this already but i'm stuck on the oil pan.
Since there is barely any clearance i would have to hold the engine on a hoist, remove the motor mounts, and lower the crossmember so i can pull the pan and get to the oil pan... Is there an easier way to this?
