Plastic Window
		Has any onehad any luck doing a patch job on the rear window
 Sure hate to have to pull it alll off and have anew one sewed in as I think the top could be a little brittle so would rather do a patch of some sort
 Mine is in the lower center and has split 3 directions
 Any help would be appreciated
 Or if anyone knows where I can get the half with window in it and I could use my rain rail .I need it tan in color
		I am about to pull the top off my wifes 94 B&T and replace it.  The top is leaking but the window is good out to the zippers.  It is just a little cloudy but still servicable.
		that would be a big help ,I sent you an e-mail or u can contact me at
[email protected]
		If anyone has done a patch job on their window, I am eager to see results.  This seems to be difficult to get desired results.
		A few of us have cut out our old windows and cut and glued in new pieces of vinyl.  Easy and about $30 worth of stuff from TAP plastics.
		my top is still on the car, its tan, good condition, come check it out whenever you get a chance, i'll sell you either the back half or all of it
as long as we agree on a good price. I'm about to check how much they
run for...
PM'd my cell#
		look at my car some time.  I glued in a window with vinyl from the fabric store with "marine glue."  Its been water tight for over a year.
		I gottcha, I was picturing just a patch panel.  Yep, definately easier to just replace with new material.
		If any of you are interested.  Gary at TRD has a tan Robbins top for an NA with the plexi rear window.  It is in very good shape.  Just not what I wanted on mine.
Give him a call.
		mine has been replaced, but it was by an upholstery shop. it was double stitched on.
		My rear window needs to be replaced. After considering the options, I am going to go the TAP Plastics route. I'm just going to wait for warmer weather.
		In case you are interested I have a tan Robbins top with the glass window frame mounted and ready to be installed.  We took this off a car that was used for a Spec setup.  Cost would be $250.
If you are interested give me a call and come take a look.
Gary
214-280-6172
		i think he forgot he posted here...
