Originally Posted by
Titus
			Stolen from some where...
The primary task of liquid cooling is to transfer heat energy from the metal parts of the engine to the radiator and then to the air. Water has a specific heat of 1.00, but the specific heat of glycol is only 0.571, meaning that a given quantity of glycol will carry away only about 57% of the heat that the same volume of water will transfer.
So....Water is a better thermal conductor than anti-freeze, but you need the anti-freeze, even in hot weather, for its anti-corrosive and lubricating properties to keep your cooling system running efficiently. If your mixture has more than 50% coolant, you're cooling ability is substantially reduced. You can even go down to about 30% in the summer to get more cooling efficiency from the added water.
