Adjusting top latches (for gabkwong)
		Here's your basic latch, albeit for the sides of a hardtop.  Same principle applies to the front latches, though. :D
http://i20.photobucket.com/albums/b2...t3r/latch1.jpg
In the middle, with a white mark on it, you should see a little bit of a threaded rod and a hexagonal piece on the rod.  There's typically a bit of plastic sheathing on the hexagonal portion, I'd assume to keep the adjustment from changing whenever you hit a bump.
Flip out the plastic sheath, as seen here...
http://i20.photobucket.com/albums/b2...t3r/latch2.jpg
...and spin the hexagonal portion of the adjuster in whichever direction works best for your needs.  From the driver's perspective, clockwise rotation should tighten, counter-clockwise will loosen the latch mechanism.
Hope that helps ya'! :drive:
