Worked on my way to San Marcos yesterday but quit after a restart when I got here. Fan works but no cold air.........any guesses?
If it is low on refrigerant, the compressor won't kick on (there is a pressure switch). You can get a can of refrigerant with a fill trigger and gauge for less that $15. It will allow you to check the pressure and add refrigerant if you need it. Older cars tend to have o-rings dry out and leak, but the re-fill kits have a conditioner that helps give the o-rings a little life. The problem is, I would think your car is too new to be experience something like this.
As far as more serious causes, I would look at any A/C stuff touched during the intercooler install. There is some "adjusting" of AC lines that occurred that I would look at. I actually had my hot-side intercooler pipe melt a hole in the A/C condenser. This happened because I didn't pay attention when removing and replacing the pipe one time, and installed it so that it was actually touching the condenser. :punchout:
If I were you I'd take it out to the nearest field and put a bullet in it to put it out of it's misery. ;)
We're full of opinions here, are'nt we.
Todd is right though. The car A/C systems have hoses that, even on a brand new car can have a small amount of leakage. When I went to school, 10% leakage per year was not uncommon.
Go to your nearest Vautozone and pick you up a can. With the new R134a valves it's as easy as connecting a drill to an air compressor.
If you want to go a little more extravigant, Harbor Freight has a set of gauges on sale for $30.
Linkie
I'd second what Todd suggested.
I had a break in the line when I had an A/A IC. I go and get it leaked tested. The dye will reveal the leak. Mine was leaking at one of the pipes going into the compressor. Had a hair line crack in it.
If the compressor is bad I have a spare that I bought but didn't ever get a chance to replace it on the car before it got totaled.
I have an appointment at the stealership on Wednesday in New Braunfels so they can diagnose it. I got a 60K warranty on it and it's got 51500 so I am going let them do their thing.
Good luck!
Stealership found a hole found in the freon tube caused by a rubbing intercooler::Rant:: and wanted $467 to fix it to which I replied, "Your Nucking Futs!!!!" So here's hoping an overcast or cooler day on Saturday when I come back. Repair work will have to wait until next week when I get the part number......
Duct tape???? Just kidding. Hope your ride home isnt' too hot.
Should have gotten a convertable, oh wait. ::StirTheP
Paging IPRESS and MadMerv!!!!
Maybe one of those guys knows a spec racer that is yanking out some AC stuff from an NB. You may be able to get the part you need cheap that way.
