Radiator Fan Not Working need help!
		Let me first say I have a 1999 Miata with a Hydra ECU. (I'm not sure how relevant that is at the moment.)
At first my radiator fan was working on and off. If I pushed on the connector where the fan is it would cut on and stay on for a little while but if bumped it would disconnect and not work anymore. Come to find out the pin on the fan motor was pushed down into the fan (Stock Fan).
So what I did was I got some Epoxy and poured it down into the fan to set the pin upright where I could plug it in and have a good connection. It worked at first; but later that day it just died all together (a small loss considering the other option was to replace the fan).
Since then, today. I read up on what to do to test the fan and the relays ect. Well I have another another 2000 Miata so I started swapping parts to see if I could find the part that wasn't working.
Well, I swapped out all of the fuses, the fan, and the fan relay switch. All of my parts tested out OK on the 2000; but still the 1999 miata still doesn't work. (just on a side note: the A/C condenser fan does come on when the car reaches a certain tempature, with the A/C off)
Well I got lazy and decided not play with the thermo switch, since I'm a little unsure if what I thought it was is the right part. The part that I was looking at has a 3 prong connector and is wired into what looks like a canister under the glove box area. I know thats what it says it is in the book. However, the wiring diagrams don't even show that that is even used anymore.
Well, I'm not really sure what else to check up on other than the ECU wiring itself. Does anyone else have any ideas?
