Let me try uploading this as a jpeg.
Thanks BR!!
Update - I just went ahead and installed the new lockset/ignition parts. I used a cutting wheel to remove the old lockset assembly from the steering column. After removal I still could not get the key out of the lockset, so I beat it with a hammer until it fell apart. It appears a small chunk of the original car key broke off in the lockset causing it to stick. The new lockset and keys work great, but now I must use a different key for the doors/trunk than the ignition.
You can get them rekeyed by a locksmith, or if you have the tumblers left from the old key lock you can swap them out to rekey the new one.
Just leave the door keys on your ignition, and press the new ignition key into a screwdriver handle, like Chris (Machismo...formerly) did.
you could always have power locks installed to a remote control
