I have a pair of Nike polorized by Marchon for when I wear contacts, other than that I have some Transitions with Ice Blue AR coating.
Sam, why such a hard time fitting your lenses to your frames? should be easy enough unless the Effective Diameter is too great and you are Myopic.
In such a case you would need to flatten the base curve of the frame using frame pliars and induce a little panascopic tilt. Your Optician should understand this and find is usefull in fitting your lenses in the frame. This is for a metal frame though with some carbon frames it is imposible and you would need to switch frames. if you are hyperopic you can go into just about any frame so long as the lens matches the base curve of the frame.
