Nice I bet it's fun
Nice I bet it's fun
your doing it wrong, your water temp on the neck cap on the front will never read the real water temp, looks like the oem sender so the ecu will not enrichen properly but that only matter pending on what ecu you have and how it's set up.
I have the AC fan running until I put a new connector on that front switch. The AEM is setup to run the AC, but since it is removed, if I turn on the AC it still turns on the AC fan.
