Crap.
The good news is battery tested at 12.44
That is also the bad news, as that rules out an easy fix I think, especially when combined with what happened next.
Tried to start the car to test the alternator, car turned and 'stated' on first crank,stumbled to 2k rpm and died.
Tried a 2nd time with the same result.
Tried jumping the car with the lancer, same results again.
I don't think it's the battery-- although it's not strong it is working.
I can't test the alternator because i can't start the car, but even with a bad alternator I should be able to start the car with the battery, and/ or with a jumper boost?
Could a bolt or something have worked loose when i went WOT? Could the new timing belt have jumped or something?
Any help is appreciated, because I have no clue. .
