http://www.ifans.com/forums/imgcache...89zoo1_400.jpg
I can't post trade secrets on public forums ;)
I'm going to try to switch probably next week. You said the dummy throttle body that came with the kit won't work on the supercharger right? The M45 is a bit shorter than the M62 if it's an interference problem with the firewall or something.
I'll have to check it out I'm still using a stock manifold I think I may have enough clearance.
Going to end this thread now, you don't have a real ecu and are running a maf. Any other solution other then how it came from Eaton will not work for you.
Fair enough.
