Originally Posted by
altiain
			Easy way to figure out if it’s the car or the driver – have someone else (like Ken) drive the car. If they are faster, it’s the driver. If they aren’t, it’s the car.
In a non-aero car, mid corner speed is all about mechanical grip. If your tires have 10-11 weekends on them, they are generating less mechanical grip than a good set of street tires. You can’t go fast on crappy tires, and you’re wasting money trying to set a car up to compensate for crappy tires.
Greg makes a good point about setup – no two cars (or drivers) are exactly alike. What works for one may not work for another. If you want to learn to extract the most speed out of your fancy shocks, you need to constantly experiment with different setups – shock settings, toe settings, bar balance, etc. If you don’t experiment, how do you know you’re getting the most out of what you have?
