Looks like we have some interesting developments in our Battle of the Kids (Novice).
Jeffrey "what do you mean I have to move to ASP" Walker-Medina is up in the first heat. In the past ASP has always been moved the morning of the event to the last heat. Everyone knows times get better the later they run. So this would be good for Walker-Medina. Obviously this will be the one time ASP won't be moved.
Brooks "I should have been a country star with this name" Oakley is also scheduled to run in the first heat. However, Oakley's Scion could run as an STX car. This would move him to the 3 heat. Will Oakley take advantage of this loophole?
David "Where did you come from" Anderson has hit the jackpot with a 4th heat assignment. Will he crack under knowing what time he will need to take that coveted 3rd podium spot? I doubt it since runs from the first heat never stand up. So his chances look good.
Now for the biggest development. Nathan "why show up for half the races or drive my own car" Reyes has struck a deal with Grant "the Tuner Kid" Watkins to drive the 93 Civic from Heck! This will give him triple the power of his Mazda but retain the FWD handling he is used to. And if that isn't enough, he even scored a last heat spot as well. He is indeed the favorite to run away with that 3rd place spot. The only thing that could hinder him is that he will be running at a higher index then he is use to.
Las Vegas has the odds as follows:
Reyes 2-1
Anderson 5-1
Oakely 20-1
Walker-Medina 50-1
Gentleman ... Place your bets!
