FWIW I have very little doubt it'll fire, however I think it is prudent to test. And the lack of indication that there's a problem only indicates that there's enough resistance in the system to keep the indicator from tripping. I have a resistor in my car, so I'm pretty sure the airbag in my woodgrain Nardi Classico will fire; darned if I can figure out where it is though. They must have really packed it tightly into that horn button! ;)
What the test will do is to confirm that the stock NA wiring is capable of firing an NB airbag. Since I'm slaving it into an NA using NA wiring (with the exception of the connector swap to make the two work together) it is as real a test as possible since I'll be firing it using the sensor (which I think is just a plunger switch, or a frangible switch; if it is the latter I'll have to short the wires if there aren't any secondary electronics housed therin. If there are, I'll need to source a replacement from somewhere.
I'm not attacking you for your decision; don't get your panties in a wad. This question has come up a few times on a few different boards and the best we can do is hope it will work. There may be variables in there that we're unaware of at the moment. Doing this test will alleviate a lot of those concerns. You can be happy with your decision all you want, but wouldn't you feel better that it had been tested? Feeling one way and having evidence to support your belief/hope should be reassuring.
