OZMDD,
Where do they usually bend at?
It does have a much smaller seat than the HF one, sometimes good, sometimes bad.
OZMDD,
The hinge, they are very narrow and lean easily.
Thanks OZMDD, I may still have to order one for light work.
Had to do some more research. On Amazon it got good reviews only 13 out of 98 giving it 2 or 1 star. No reports of bending, biggest complaint was that it leaked down or did not lift high enough.
Of course I don’t expect it to be a heavy duty floor jack I know it’s the cheap stamped steel model.
I decided that I wanted the jack with the larger pad, the one on the steel jack looked real small. Ended up getting the 2 ton aluminum Home Depot jack for $99 in store. It’s $180 on line.
http://www.homedepot.com/p/Husky-2-T...0110/204799757
That HD jack looks pretty nice. I have a "Hybrid" Acran from Costco that was $99 as well, but I would guess its about 50lbs. Looks pretty similar though.
Havent tried it on the Miata yet, will have to check before I take it anywhere, may have to find one with lower clearance, it is a 4" minimum, which is not an issue with the Jeep...
Does anyone have any jack stand recommendations?
The best recommendation is to change your tires at home.
