Strange. Are you sure you've got the bar in the right way? If you take the bar out, flip it around, and reinstall it, is the angle that the endlink makes with the flats on the end of the bar better or worse?Quote:
Originally Posted by Screamin'Screw
If you can't get a stock endlink to line up, you'll be completely screwed with an RB endlink - the way they're designed, they have a very limited range of pivot motion at each end, which means they're a lot more difficult to line up than a stock endlink.
What he said. Those springs are storing a tremendous amount of energy, and you can rent spring compressors for free at any VatoZone. Why on earth you would want to stand on something wrapped in a towel that had the same energy as a rifle bullet is beyond me, but it's your foot/hand/body/garage wall, not mine.Quote:
