Yep... Donor parts:Quote:
Originally Posted by Adam Payrot
- 1.6L engine and gearbox - complete with inlet tract & exhaust manifold and lambda sensor
 - Air box and air flow meter and both pieces of pipe work and retaining clips and air box mounting rubbers
 - Complete wiring loom, ECU, fuse boxes, dashboard switches, clutch pedal switch, sensors and relays
 - Instrument panel cluster
 - Upper steering column including steering wheel, crash pad, indicator stalks, ignition barrel and key and top and bottom cowl
 - Lower steering column (needs modifying)
 - Diff and casing complete with rubber mounting bushes and buffer plates
 - Rear uprights, hubs, discs and calipers including top upright rubber bush still fitted
 - Handbrake lever and cables, compensator & all fittings including retaining spring clips
 - Steering rack, track rod end joints and nuts
 - Front uprights, hubs, discs and calipers
 - Wheels and tires and wheel nuts
 - Propshaft (needs modifying)
 - Driveshafts including joints, lock nuts and hub nuts
 - Front bottom ball joints including castle nuts
 - Horns
 - Cooling fan
 - Side repeaters
 - Fuel filter and bracket
 - Carbon canister, pipe work and mounting bracket
 - Catalyst converter
 - Interior mirror
 - Screen washer bottle and pump
 - Battery and mounting tray including clamp and fixings
