Originally Posted by
Chris Fain
			Agree w/ most of what is being said, it really boils down to what you will use the car most for.  With bigger brakes comes getting brake bias correct.  They tend to lock up rears more easily when not dialed in.  Pads are first and foremost.  Good bite on stock rotor is still alot of horsepower for braking for the Miatas.
Fronts should be alittle more agressive than the rears.   Brake fade should be minimum w/ either set-up as these are momentum cars.
I set mine up with a Hard-Dog Double X-bar and harness bar, then did the sway bars.  For fun, go w/ sways first, noticeably different.  However, noticed a great deal of chassis stability w/ the roll bar first.
