Yep, if you are in gear driving and the rpms pick up without accelerating then it is the clutch disc. If the slave/master cylinder is leaking then you will have trouble shifting.
If the clutch disc is getting worn out but is not completely gone yet, then it will probably still work well when cold.
Try driving for a while and get the car warmed up plenty then stop and engage the brakes.
Put it in first gear and slowly release the clutch pedal.
If the clutch disc is good the car should bog down trying to fight the brakes and eventually it will stall if you release the clutch all the way.
If the clutch disc is worn out, then the rpms will be allowed to rise instead, and if it is completely worn out it will free rev and probably make noise.
