Texas Region Divisional Info:
- There will be quite a bit of traffic on the site Friday evening starting around 6pm. The area that we will be using for Grid during the day needs to be used by the Baseball Stadium patrons in the evening. Please keep this in mind when coming into the site. Baseball traffic will be coming into the site using Gate 2. You want to enter at Lone Star Parkway off Beltline road.
- Please Take Note:
It’s going to be HOT all weekend! The forecast shows temps right around 100 degrees for all 3 days. Please take the following advice about the heat & staying hydrated:
• AVOID CAFFEINE & Soft Drinks. These will dehydrate your body!
• Take frequent water breaks (1 glass of cool water/20 minutes of heat exposure)
• Replenish electrolytes with sports drinks if heat exposure is longer than 1 hr.
• Take breaks in the shade when possible
• Wear a hat, light/loose fitting clothing and sunglasses
• Use sunscreen that is not oil base and reapply on a regular basis (special attention to back of neck, nose, and top of ears)
WHAT TO DRINK?
Ã* COOL WATER
• Normally 6-8 glasses per day (8 oz./glass = ½ Gal.)
• Add 2-3 MORE glasses for each hour in the heat
8 hrs exposure = 24 – 30 glasses or 2 Gal. per day
• JUICES (O.J. & Tomato Juice are great choices)
• LOW FAT MILK
• DILUTED REPLACEMENT DRINKS
Half water-half drink after being in a hot environment more than 1 hour.
There are indoor Restrooms at Lone Star Park. In addition, there is an air-conditioned lobby area just inside. If you are beginning to feel like the heat is too much for you, PLEASE get help & move to an air-conditioned area!! Our Safety Stewards have bright yellow/neon green hats. Find one of these guys & get help!
Corner Stations will have coolers of ice & water. Every effort will be made to keep these stocked during the event. But, please plan ahead & bring some of your own COLD WATER in addition.
- On last item. Due to SCCA National Solo Rules, Non-SCCA Annual Tech programs can not be honored for this event. SCCA Solo Rules do not recognize Non-SCCA Annual Tech programs. Please understand that this is out of Texas Region’s hands & is not an option for our Tech crew at this time. Per a note from Risk Management at the National Office, there is no leeway on this item.
Thanks,
Brad
