Originally Posted by Jiggerachi
			Ok, well the mechanic basically said the same things as I already knew, but also suggested that I check the condensor for blockages.
I looked under there & notices significant rock dings, small pebbles & bugs imbedded in there. I snapped a quic pic of it.  Im sure this is normal for any car thats this old, particularly low to the ground & drivin frequently through a perpetual construction zone(121) but do yall think this is bad enough to be part of my problem?? I plan to clean it out thoroughly anyway.
[IMG]http://img.photobucket.com/albums/v449/jiggerachi/Radiator006.jpg[IMG]
Also, after driving through moderate heat / traffic / AC on, with the new radiator cap the problem seems to have diminished significantly. I still see slight rise & fall of temperature, but I am not convinced these fluctuations are not any more than normal(up to but never over the half mark on the gauge). Definately more moderate conditions than earlier, but I have seen the temp go way up in these same conditions.
I guess at this point, time will tell, I just have to wait for the next heat wave & uber rush hour traffic. But for now I think ill put the replacing of expensive parts on hold for now.
I have heard of an off the shelf radiator cleaner that supposedly works on older engines, anyone know of any ill effects this stuff might have on the miata cooling system? I might give this a try if it wont hurt anything.
