The Budget ZZZZ sounds like a Romo audible to me. :)
No wise cracks from the peanut gallery. If you aren't going to Hallett you can't talk. :burnrubr:
Now is 90% chance of rain on Fri! :-(
Track time in the rain? Perfect learning environment.:)
But the really important stuff: Trip Adviser Sands Springs Restaurant list:
http://www.tripadvisor.com/Restauran..._Oklahoma.html
Great learning opportunity, lousy way to spend a weekend you've waited a year for. :(
If it rains all day Friday, we may find a new Aquaman. Ashley won't be there to defend his title.
Friday will be car control day.
Saturday will be one of those postcard, glorious, day after a cold front in the Fall never forget days. :)
It'll be OK.
Don't forget to BYOB for Saturday's banquet.
awww hell yeah, time to bust out my cooler...
Totally forgot to bring tools home from work today, so I'll have to stop in at work in the morning to grab a couple of things. Also I left my wheel lock key in my tool box by accident, so I REALLY need to drop by so I can grab that... ughhhhhh
We had a great time today. I got down to a 1:34.6 in the AM sessions, but then my clutch malfunctioned. Glad I have a trailer! I might have found more time in the warmer afternoon, but we'll never know. I still drove Avarice's car one session on the PM, which is pretty much the same as mine. I also drove another friend's all stock 1990, with 185mm tires and all! It was fun going back to stock.
Good times. Good times.
Ditto, had a great time! And, when I got back to my friend's place in Tulsa, his neighbor threw me the keys to his 580 whp Viper. :)http://tapatalk.imageshack.com/v2/14...b124ad0c96.jpg
Well, How was it? Where's all the bragging? What was the carnage? Where are the pictures?
Good times. Did it both CCW and CW. Friday was in the wet. First session was like ice. Saturday was a gradually clearing cold front day with highs in the low 60s. Good temperature for Rivals, too bad both rears are flat-spotted.
Managed a 1:32.4 going CCW. Best lap is #6 starting around 7:50 (I'm chasing Neal Bellamy for most of this):
1995 Miata 1:32.4 at Hallett CCW (9/13/2014) - YouTube
And, here's the obligatory off at Turn 1 on the last session of the weekend (the hot pit guy and I have a good laugh about it):
1995 Miata Big Off at Turn 1 Hallett (9/13/2014) - YouTube
Unfortunately, I hurt the engine on the 4-2 downshift at turn 2. 949 Racing's 95R lost an engine at Hallett 2 years ago the same way. Basically, it's a money-shift setup and, in my case, I bent some intake valves. My compression is 50-160-70-175. Leakdown shows 15% on #4 and the rest can't even be measured. Air is blowing out the intake valves big time. Head rebuild (with Supertech valve springs this time) coming up.
Bragging? How about cold hard facts: no miata was greener, no miata had a bigger wing. I was in a class of my own ;).
I hadn't driven on the track in 2 years and had never been to Hallett before. Love the track. Perfect for a normally aspirated miata. I forgot to turn on my lap timer for all but 2 sessions. So I can say I at least ran a 1:36.70. I can only assume I pulled off one or two sub 1:30 laps on those non-timed sessions... ;)
Thank you gentlemen.
I'm using an iPod Touch and an XGPS150a 5Hz Bluetooth GPS. Capable of 1080p, but I usually record in 720p because the video only takes half the memory space and it's still more than enough resolution.
Write-up on the install here:
http://www.miataturbo.net/build-thre...6/#post1100556
I've used CMS Laptimer in the past. It has a great grip circle display. It also creates its own track layout so super easy to use. But it forces you to use 1080p mode and has some bugs.
Now I use TrackAddict HD. Great video, very bug free. Allows 720p which saves a lot of space. You do need to select the track ahead of time though and the grip circle isn't nearly as nice as CMS.
A lot of people like Harry's laptimer, but I haven't tried it yet.
No, hurt the engine Friday afternoon. There was no blowby and no oil consumption (i.e., bottom end was fine), so kept running it. You probably remember that I thought I might have a clogged injector and was running some Seafoam on Saturday. It wouldn't idle worth a darn Saturday but still ran pretty well with revs above 2K or so. I knew it had to be either an injector or valves. Hoping for the best, expecting the worst. Murphy does not disappoint.
The fast session was the next to last Saturday where you, Neal and I lined up in the first three spots and went at it. Good suggestion. It was a great run and a lot of fun.
In two days, I did 172 laps total, about 310 miles. My best lap was in Saturday's last session, a 1:37.4 sec. There was only 5 cars in grid for that session, but as many as 20 in one of the earlier sessions. The only thing I did to my car was add gas, check the front brake pads, oil and air pressure. The car ran great all weekend. I didn't have any offs, but I wasn't always pointed in the right direction.
I'm going to add my .02!
Hallett was amazing! I was totally surprised how well a nearly stock Miata handles with a worn out suspension and 320TW street tires! I kept checking everything but the car didn't need anything but gas and a better driver.
This was my first track day, and I had an off in my first session, but it was low speed and caused no damage. Definately awaiting pictures of me in the grass. I almost went off 2 other times, but I kept the car pointed in the correct direction and on track, so I can't complain.
Moonie, I don't know how you can drive such a clean car at the track, that car was the best looking car at the event IMO. Very Green indeed.
Hornet, sorry to hear about your valves, but I'm awaiting pics.
I'll be going next year for sure, will they let me go Friday in the intermediate group if my only track experience is Hallett this year?
I ran a low 1:42 on my third to last session chasing the guy in novice driving the silver NC! I only had the transponder on my car the last 3 sessions, but I'm pretty sure that was the quickest time. To most of you a 1:42 is slow, but it felt fast to me lol
1:42 is very respectable for a first timer. One of the other novices was running 1:45's.
There is another track day coming up. The North Texas Miata Roundup will be at Eagles Canyon Raceway on Oct. 24th, a Friday. The registration fee is only $60.
http://www.internetcarclubs.com/Even...undup2014.aspx
It's been a while since i had been to a Miata event at hallet. I did go two weeks prior on 2 wheels and thought the track looked good so i decided to take my car.
Not sure what times i ran on Saturday as i forgot to turn on my cell phone lap timer... Probably not that accurate anyway. But Friday i ran 2 sessions and was pretty consistent at 1.31 - 1.32 i can only assume i improved the next day with warmer tires and Different tire pressures.
I had the pleasure of being an instructor for Dustin whom did great for his first time out. It was nice to see the strides he made through out the day.
Advance group session 3 me and zig running together.
https://www.youtube.com/watch?v=ea0eOnuxn2w
[QUOTE=hornetball;305323]Good times. Did it both CCW and CW. Friday was in the wet. First session was like ice. Saturday was a gradually clearing cold front day with highs in the low 60s. Good temperature for Rivals, too bad both rears are flat-spotted.
Sorry about the engine - hope it's fixed soon... Nice laps/times! What size tires were you running?
I'll have the head back on Tuesday and the car will be driving Thursday evening. Got another track event to get to!
It was actually fortunate because the exhaust camshaft was starting to grind the cam saddles/caps. Apparently, machine shop didn't clean the head well enough before putting it together last time. Caught it early.
Got 2 new Rivals to get rid of my flat spots too! Should be golden. The Rivals are 225/45R15s.
Truer words have never been spoken. I was pleasantly surprised with how fun the car was in mostly stock form.
Now I think everyone who owns a Miata needs to do some sort of HPDE.
Interesting. Do you know if it will be short course or long course? If long, I'm pretty sure my brakes won't take the abuse of those super long straights, but thats just from me looking at the map. $60 is insanely cheap though...
When I go next year, if I can go Friday, I bet the CW orientation will completely throw me off for a session or 2. Is there a certain time needed to be in the intermediate group? I don't mind being the slowest in the group, but I don't want to make an unsafe situation either.
Yeah, your probably right. I'm not saying that it couldn't be done, but even though the tires I had on the car were decent and new, they certainly were nowhere near RS3 or Rival grip levels. I don't think I could pull off anything much faster with the current setup without tons of seat time. The car is heavy(for a Miata) and still has all of the creature comforts and a beat up stock suspension. Also keep in mind 1:42 was my quickest, not my norm that day. I was 1:43 pretty consistently without Mike in the car. I only ran the transponder the last 3 sessions, I was focused on learning safety and learning to watch the flag stations during my first 3 or 4 sessions.
Another track noob named Dustin Nation was driving that cream colored NA. It wasn't prepped at all, but had some really good 200TW tires. He turned in some 1:39's :clap:. Between being lighter than me and the tires, his car had a ton more steady state grip than mine. Makes me want some better tires!
Mike,
You were a great instructor! My first stride was making a pass in session one, immediately followed by a stride into the grass LOL!
Maybe next time at Hallett I will cure my early/over braking habits. I bet it would take a second or more off my time just by fixing that into turns 1 and 2 alone.
One of the hardest things to learn that day was keeping my foot on the gas through most of the turns. It's just a natural reaction to let keep the foot off the gas when my car was running out of grip. It was an amazing moment when I finally realized the solution to that was to just give it more throttle!
For ECR high temp brake fluid and better than stock pads are an absolute must in my opinion, even for a novice.
If you've been bitten by the track bug, I highly recommend getting practice on PC with a quality physics based simulation. iRacing is great but has a subscription fee. Assetto Corsa is a solid and affordable sim. Even Gran Turismo can be valuable training. You have to understand that these sims are NOT a substitute for actual track driving, but there is so much you can learn and practice in a sim. It is fantastic brain training that turns into muscle memory. Oh, and you really have to get a wheel and pedal setup that has a clutch and a stick shift to get max benefit out of it. I'd probably even offer some sim-instruction if you're interested. I'm not the best driver or the fastest, but I think I'm competent, aware, and safe. I think those three skillsets will enable you to have fun and decent enough pace.
Yep. Motul RBF600 and some HPS or HP+ pads are a pretty cheap and safe combo even for ECR, and will still be a setup you can live with on the street.
I used to play Gran Turismo a ton(3 years ago), but haven't really played any others sims. I didn't have the wheel with stick shift and clutch though. Aren't those setups kinda expensive? Also keep in mind, my computer is a decent quad core laptop with 6GB ram and SSD, but it is still a 4 year old laptop now, and I don't want to fry it, I have to use it for running stress analysis and also simulations. I think I need to pop off my ECU and apply some fresh thermal paste, I hear that it gets old and crumbly after a billion heat cycles.
One thing holding me back from something like this is definately time, I'm a senior ME student, and an intern at a Aerospace Company. Thanks for the suggestion, it seems like something I would enjoy as well.
I'm not necessarily worried about the fluid, I have a pressure bleeder and a stock of ATE SuperBlue. The fluid is less than a month old. I would be worried about these pads at ECR, they have plenty of life left, but they are some unknown pads that came with the car. They held up fine at Hallett, but that track isn't so hard on the brakes.
Luckily, I have a set of Stoptech Street Performance Pads on the shelf, I guess all I need is rotors, I don't feel like taking these rotors to get machined, and I won't just swap pads and call it good, the new pads won't properly bed in without a clean, machined surface. Now that I think of it, I have a set of rear rotors on the shelf with less than 1000 miles on them. I guess I only need front rotors LOL, I'm thinking I have to go to ECR now!
This all started because of you, Rick!
ECR looks like a fun track, but I think they should repave, my car won't do too well with the worn out shocks. It looks quite rough in videos.
