Looks fun. I thought you had 2 sets of 6UL's though?
Are you using the MS for EBC?
Chris
Chris
here's an old "before" picture, lol
http://memimage.cardomain.com/ride_i...0003_large.jpg
i have a manual controller. The cool part about the weak spring is a lower boost threshold. you can hold the wastegate flapper closer to the housing, so the turbo spools faster. There is a sweetspot between early spool and overboost. I'm using a GM boost solenoid for EBC / TPS based boost control.
I ran out of fuel for some reason at 200whp on the dyno. So I bought a fuel pump and I'm about to order an aeromotive regulator. I think 150k miles may have done those parts in.
I should note that the car feels awesome though at 200whp, and it hits 12 psi (creep) at 3600rpm in 4th without the MBC (it will spool lower). It feels like a rocket even with weenie power, this car is going to be great with decent tires and track-fun. Now I'm driving a car that can get away from me, which is a new concept. I haven't driven a car with more than 94whp in about 8-years, so I'm all smiles right now...unfortunately there is still a lot of work to do.
Congratulations on your hard work. I know you'll enjoy it in the long run.
http://i39.tinypic.com/976zqq.jpg
like I said, this will get much better next week. It feels pretty serious about torque at 4k rpm. 200whp still feels like a girl car on the street...but it could be really interesting on the track.
oh, and my lc-1 is whacked out (probably user error) and I'm getting crappy signal to the MAP sensor:
http://i41.tinypic.com/2hd1c3a.png
lots of work to do
but not bad to see 10psi at 3800rpm on an 8.6:1 motor that everyone told me would be miserably sluggish...and nothing crazy on the spark map:
http://i39.tinypic.com/2h848hs.jpg
I still say push 17-18 psi in town. I drove the jackel at 14psi for a short period. I decided to play safe and back it down to 12.
With the setup you have, and a 6-speed in the garage. I would atleast push 300-350. That is very nice setup.
so I'm putting in an EGT gauge because the glowing turbo shit makes me nervous. I know its supposed to glow, but its not cooling as fast as my vw's did, which makes me nervous. Maybe this ceramic coating works better than I thought it would. Hopefully the chra doesn't mind.
I don't need 300whp, its not that kind of car. Its made to chase expensive cars on a track. Hopefully it will and do it reliably.
http://i43.tinypic.com/10i5d13.jpg
the next pic will show everything unnecessary removed, cleaned up, COPs, and other assorted coolness.
Why don't you just drive it and enjoy it for a while?
Hey, what's your specs for your engine stethoscope?
Chris
That looks maaaavolous.
Looks very nice, even if you still have some tidying to do in there. Aside from the canister and the coil of hose, how much are you planning to delete or tuck?
I'd love to take a peek at your reroute setup next time you (and your car) are actually in town.
You need to let Chris and I do the mojo to the interior and get some damn steering rack plugs!
The wiring will be simplified and made pretty, I have slim fans I need to make a shroud for, and I'm also probably going to do the AWR header tank and swirl pot. Its cheap headroom at $100 each.
I have an adjustable scooper from BEGi now, and there's going to be a 4"+ splitter set-up coming down the pipe too which will incorporate the scooper and oil oil cooler. I think I need all the air I can get on the heat exchangers.
I have to get the bumper and FM hood painted too. Then I'll be ready for the track.
Looking good, must be a hoot to drive.
