Re: Question removing rotors
				Originally Posted by Jiggerachi
 Looks like they pretty much covered it.  Nor do I  have a recommendation on shops for this, sorry.
I know...wasted post :oops:
			I am thinking about getting my front rotors turned this weekend, theyre warped like whoa. I have heard about how diffiicult the Civic rotors are to get off due to the small screws that are on so tight you need an impact wrench to remove them, if that works, most people just end up drilling them through to get the rotor off.
 No, Miatas do not have the evil little screws that Civics have. I used to own a CRX, so I know all about them. :evil: FWIW I was always able to remove the screws by whacking them counterclockwise with a sharp-edged cold chisel; I never had to drill them out. However, I removed the rotors on a regular basis due to track use, so I could understand how you could have bigger problems with a high-mileage street car.
Also, I am a believer in the philosophy that if your Japanese car has warped rotors, you should replace them, not turn them. Turned rotors will frequently re-warp. Plus, if your car has 100k+ miles, the rotors are probably toast anyways. If the rotors are still good and you REALLY want to turn them, get it done using one of the machines that turns the rotor while it's installed on the car. However, getting back to my previous point... turning the rotors removes material (duh), and even if the rotors were OK when you started, they may be too thin by the time they've been turned enough to fix the warp. :(
