Too Tall, Part II (or New Dog, Old Tricks)
		I checked out the new 'No Brainer' Hard Dog bar that Craig pointed me to.  Sounds good so far, but I wanted to really check it out.  I got the measurements for the cross bars and used a C-stand to hold some broom handles in the appropriate places.  It is better than anything else I've seen, but is it good enough?  Plus, this has raised other questions that I now humbly set before you all-knowing Miata gurus!  ;)
Here are two pictures with me sitting in the car with the seat back in my normal position (I'm in normal driving position in the first and leaned back against the headrest in the second).  Keep in mind that I could tilt the seat up a little to get an extra inch or two more.  The blue dot represents the top bar (I added the dot so it was easier to see than the stick end).  The green is where I could put a harness bar.
http://www.johnlanning.com/RB-1.jpg
http://www.johnlanning.com/RB-2.jpg
Still a bit close, but better.  What do you guys think?
I thought about adding the harness bar at about that height for the main reason that the seat would hit it first (or start at rest against it) and, in theory, flex less (although it will compress).  This might work as a buffer, keeping the upper part from hitting the top bar, or at least slowing the impact.  Obviously padding will still be used!  ;)
Merv mentioned lowering the seat, but looking at where my head sits, I don't know that I could lower the seat enough to make enough of a difference.
Now here's another question raised by looking at this (I know, but humor me, I'm new to the whole roll bar thing ;)  ).  Look at how much higher my head is than the bar.  In a flip over, is this going to do anything at all for me?  Is this entire debate just a waste of time for someone as tall as myself?  I'd like the additional measure of safety, but if it really won't do anything in a wreck, I could spend the $$ elsewhere...
Sorry this is so long.  As pricey as these things are, I want to make sure I do this right the first time!  Thanks !!
