I think I'm loosing my coil?
		The last few days my cars been acting funny on startup.  It usually starts fine, but then it will start 4 cycling (hitting on every other compression stroke), but then clears up.
Today, on my way into work, on I-20 the car shut down, as if I had turned it off.  I went from 70 to 50 mph, then it came back to life, and I drove on into work.
Does that sound like a coil going bad?
TD
		Cam Angle Sensor!!!!!!!!!!!
		These symptoms sound familiar!  About three months ago, My car started stuttering on startup (or not long after).  The problem was always intermittent, and confusing.  I, too thought it was the coil.  Then, one time, I was driving down the highway, and the car shut off momentarily.  Another time, it shut off long enough to strand me for a couple hours.  The problem was the CAS.  I also discovered that 1.6 and 1.8 NA cars have different Cam Angle Sensors, but they happen to be interchangeable.  I currently run a CAS from a '92 1.6 on my '94 1.8, and the car runs predictably and reliably again.
		New (used) CAS in-place and it's acted up twice since
		OK, since I've installed my new-2-me CAS, I've had the same issue.  So now I'm thinking Coil(s).  It's done it once at idle, and again sounded like it was hitting on 2 cylinders, along with a very rich smell.  It's also acted up twice on the hwy, by shutting down for a few moments, then springing back to life.
I've found no loose connections, and I'm unable to reproduce this problem on demand, although I've tried by moving wires and shaking things up un-hood while idling.
BTW, there's nothing to the CAS, I see no reason they charge over $600 at the Stealership.
TD
