I thought blown sixes were now the rage for Sevens. ;) Just kidding -- I think a Seven should have a four.
PM sent. ::Banana::
I call the windshield...
I've got a 4 pound hammer in the waiting.
Technically this isn't an OTM.
I was referring to Todd's plan. His Seven will have large Miata content thus it's not an "Other Than Miata". Now if he was using a different donor car, I'd agree.
I need the left side steering wheel button to finish off my collection... can you spare it? :D
Removing airbags is easy. Just apply 12 volts to the right set of wires. :D
Clip the red wire...
Or was it the green wire.::Blowup::
Fun with airbags or is it air with funbags...
I can help you Titus. I've messed with my funbags, errr... airbags many times.
Easy.
1. Remove glove box
2. Unplug blue and orange connectors
3. Remove (4) bolts under the dash that bolt to the bottom of the airbag module (14mm IIRC)
4. Remove airbag module
The drivers airbag is (4) bolts on the back side of the steering wheel. It also has the blue/orange connectors.
Bring them to the Wednesday night GTG and we can get Wags to sit on them when we blow them. :D
Todd, if you are gonna sell the bags you would get more $ if you have the airbag control module also. When the bags blow the module frys itself.....so whoever buys your bags will need the module also. The only problem is you have to pull the dash to get to the module, it is dead center in the middle of the dash at the base of the windshield.
Also keep in mind if you ship them, they are considered dangerous goods and an considered explosive. It's expensive to ship DG but if you do not declare it and it gets discovered, it's a federal offense.
That is Montego Blue, right? It's difficult to tell from the pics. If it is, I want the front bumper, both front fenders and the hood.
you going to sell that factory cd player? i sure could use something to replace this crappy old tape player i have in mine
I don't know if it would work in his car. The Bose is a 'dead head' and requires the amps to work.
Plus the mounting is totally different. His mounts in by way of a bracket with screws and ours mounts like a ford with spring clips.
He'll tell you "they all do that". And he'll be right. And he won't work on it.
It's not an actual potentiometer - it's a rotary switch that just clicks as you turn the knob.
AFAIK, no one has developed a "standard fix", though the PO of my car said he uesd to occasionally pull the knob and shoot contact cleaner into it for a temporary improvement. I found that a cheap aftermarket headunit was a much more effective repair... ;)
Don't knock it. I would have much prefered the one that has a screw in bracket. The radio is a lot more secure and less likely to be stolen since it would take the theifs 10 minutes to get it out verses busting up your dask and ripping it out. Of course they will still bust up your dash and slit your top. :rolleyes:
Check out BlackRoadsters Sub.
The hardest part is getting the center bezel out. There is a hidden screw under each of the vent bezels. It's not that hard. You will need to find a pocket that is a full Dinn size or you could put in a din size Alpine speaker in the place of the pocket. Nissan 1999 Frontier had a full szed pocket as did a lot of the Toyotas. I would try to find a pocket thatcomes from a car manufacturer rather than a Scoche or Metra. They give you a lot more room and look a lot better IMHO.
You can get a wiring harness kit to do all of the wiring out on the bench and all you have to do is plug it in when you are ready. The pocket I got for my nissan was about $15 dealer price. Metra wiring harnesses qre qbout $10-15 usually. Miata.net has the info needed to do this.
Linkie
Mod's feel free to move this drift into its own section...
thank you i will check that thing out
Hasn't this gotten off topic? More pictures of Locosts!!!
