Wiring Conundrum - Con't.
		2:24 A.M. - Frisco:
So I was removing the airbag wiring (see HERE for early details) So now it's back together...or so I thought.  My tach isn't working... nor is my oil pressure gauge, fuel gauge, or temp gauge.  The fans are now wired in parallel and they aren't rolling on. I could see the radiator hose start to bulge from the heat - thermostat wasn't switching on.  My windshield wipers aren't working either. The lights are coming on fine - both in the dash and the headlights.  Blinkers are fine, so are the emergency flashers...taillights and reverse are fine. I'm thinking I'm missing a ground wire somewhere...
The engine itself is ok... it started just fine... and aside from the potential overheating, it should be fine.
I'm at a loss here fellas...
