Sitting in the driveway listening to a song on radio this evening I see the temp needle start to creep up. This is the 2nd time it's done this since I've been driving it again. It spent 5 months in the driveway this fall while I drove the other car (strange circumstances, car was running fine).
Popped the hood and the fan was blowing but it seemed a little weak. Hit the AC button and when it engaged the temp actually went down. Assuming it was because of the extra fan running I got out and checked, the AC fan was blowing at least 200-300% stronger than the drivers side fan.
I am assuming that both fans should be moving the same amount of air and this is not normal?? Are the bearings going out in that fan? I have a spare set of fans in the garage if that's the case but wanted to make sure before I started tearing things apart.
The coolant was a little low when I started driving it again but I topped it off a month ago. It's been over a year since I flushed the coolant and probably needs it, should I run some radiator flush through it while im at it? That being the case it still shouldn't be overheating sitting 5 minutes on a rainy afternoon in March with the AC off. The temps afe fine on the road so it's drivable now, hopefully I can fix it while it's still cool...there's no way I would make it through summer like this.
