Anybody know of a local source that has handle nuts? This is what I'm talking about in case you're confused. ;)
Attachment 3787
Used for installing a trailer hitch when you can't get your hand or finger into the frame rail.
Attachment 3787
Dave has a welder... I'm sure you could get him to handle your nuts for a small fee...
Gee TC... I thought we agreed to keep that to ourselves!
Anyway... Sammm.... here's a link (top of the page), it's a "kit" so it may have more than you really want, but it does appear to have two of the handle nuts... http://www.hitchesforless.com/tools.htm
But yeah, if you have the right sized nuts (left this one open for jokes), I can weld a tab on to them for ya...
I used a coat hanger and self locking nuts since I didn't have the correct hardware.
http://img.alibaba.com/photo/2341769...ts_DIN6927.jpg
YMMV
In order to facilitate easy removal at select events, I just drilled holes on the opposite side of the mounting points and purchased new bolts and nuts. That way, both the nut and bolt are exposed for wrenching access. Why not just do the same?
jrj512 so you are depending on that sheet metal tube to hold the hitch in place? How tight can you get the bolt without deforming the tube?
http://bjoern.brembs.net/cars/miata/...off1_small.jpg
Just be careful putting a coat hanger around your nuts.
I am still using the same mounting locations, but instead of stopping after the first hole, I just made a second through the opposite side so I can fit a bolt all of the way through. From what I can tell, the only reason for the handled nuts is so they can say that no drilling is required, which is true.
So, using Mick's pic, the put a pink square around the two bolt holes that you use with the handled nuts. I just drilled a hole for each bolt on the opposite side on that piece, too.
http://www.dfwmiata.com/attachment.p...8&d=1266866094
On my car, the inboard holes on that rail are where the rear tow-hooks are mounted. May be different on the 1.6 NA's?
I'm going to try the Meesh method first...thanks guys.
Buy the right nuts, get extras, go to an indy muffler shop and have them tack weld a rod on each one. Should be cheap. Don't use old nuts they get brittle.
I can weld a handle onto a nut for you for free. I'll be at my shop tonight, give me a call if you want to head over.
jrj5121, I think we understand what you did. I think the concern is that you can continue to tighten that until the box/tube collapses.
I use lock washers so I do not need to apply 10,000 pounds of force to the nut.
Lowe's hardware and a coat hanger FTW! Bring on the warm weather! ;)
Why do you need a life raft on your car? Do you expect to be stranded on the side of the road?
Or do you need to carry your bike somewhere to ride it?
That's like taking a beer to a bar ;)
Sometimes, I crack me up :rolleyes:
Okay, who took Hal's meds from him?
I'd invite you along, but I don't think your bike would fit.
http://t3.gstatic.com/images?q=tbn:3...5102602_pm.jpg
Nice jacket.
Jacket?!!! I thought that was a blanket draped over the vacuum cleaner. Good eyes car dealer.
Where did I see that jacket?
Attachment 3800
