i am looking for some help with replacing the rear axle and/or rear right wheel bearing on my 99 miata.
shop recommendations in the fort worth/benbrook area wanted.
or if you want to help me we can get it done in my garage/driveway, i pay cash :)
Best shop on the Ft. W side of town = Miata Solutions
http://www.miatasolutions.com/
This is probably something you want done at a shop because you need either a press (and a big one at that) or a brave friend, ball hitch, and a sledge-hammer. It's one of if not the biggest pain in the asses on a Miata.
Use anti-seize on the splines and they will pull out by hand next time.
+1 for Miata Solutions.
Trust me it will be. It takes a pretty large hydraulic press to get the damn thing out. If you do it in your drive way take it ot a machine shop with the new bearing and have them press it out. However much they charge....it's worth it.
I did a rear hub bearing on a Focus which is built similar except for not being a driven hub like on the Miata and even with a hydraulic press they were using a lot of force to get it out and get the new on in.
I managed to stall the 30-ton press every time I've done it (4-times). The sledge hammer works every time.
in contact with stevan from miata solutions right now.
Stevan from miata solutions is awesome and very reasonable on the north side, Meadowlake Enteprises/Team MER is good on the south side.
If MER is charging $170 for 15-minutes on the dyno I'd hate to see what they charge to swap rear wheel bearings.
Wow that's a good chunk of change.
Good work though
at this point i am thinking i need to replace the rear hub assembly and halfshaft. anyone have a spare lying around they want to offload? i already contacted mazda heaven via email, but they don't respond very quickly. will call them later on.
Just bought the rear assembly from mazda heaven. hope it solves my problem. 125 plus tax.
anyone want to come swap it out with me? i have some nice miata parts that i would gladly give you in exchange for your labor.
I'd be willing to help but I'm working till next monday and on that day I'm off to get a bumper from the Dallas area.
Is the car driveable? I live up in Saginaw and could probably lend a hand in my garage. As long as you have a socket that will fit the spindle nut.
Its 2 bolts and the half shaft. If you can do brakes then you can do this.
Make sure the lower bolt is not bent. (common)
No need to change the half shaft, if that is damaged you have bigger problems.
Is the half shaft bent FI994k??
If it bent other stuff is also bent and your going to be spending some additional dollars.
At this point I assume it is, but we all know what assuming can lead to. What's the easiest way to tell which part is causing the vibration?
Have you switched wheel/tires to make sure that it's not the vibration?
Yep. Already switched wheels, tires, had them balanced, checked...etc.
Replaced entire brake system...
Pos, you have a diaLmeter I can borrow?
got my parts, apparently the half-shaft wasn't included in the quote, but got it for a nominal fee. also picked up a socket for removing hub, breaker-bar, and hinges for hanging some closet doors in my house...now to find time to do all this work!
