1990 NA No Start / I've checked just about everything / Please help
This is my friends car, i sold him this car about 2 years ago.
He said the car started up fine and he was driving a few miles away to go to work and the car just died.
I went to go help him check the car out tonight, i looked at the obvious stuff, the battery is getting 12.5 volts from my voltmeter, i pulled the gas line and as the car is cranking over the gas is spitting out, i pulled one of the spark-plug wires as he turned the car over and was getting spark.
I tired unplugging the MAF sensor as he was cranking the car, it didn't seem to make a difference, i checked all connections unplugged TPS sensor and cranked the car didn't seem to make a difference either
I checked the timing belt and its not broken or anything, its turning with the engine as its being cranked.
The car started a few times and then just died again, you could hold the gas to keep the revs up and it sounds smooth (not misfiring) then it goes down to low rpms and just dies out again
I tried raising the idle screw up, didn't change anything im pretty much stumped out at this point,
Do you guys have any ideas, its a 1990 NA, 5 speed
