Shocks, springs, coilovers, sways, etc...
Thanks in advance!
Thanks in advance!
Endura-Tech coilovers (twin tube, single adjustable) 8k F, 5k R
Progress RX8 FSB (32mm)
Hotchkiss RSB/ Mazda RX8 Yellow dot RSB
Mazdaspeed LSD
Mazda Competition MS-R parts.
KIT, COIL SPRING $230.00
Part No : 0000-04-5105-KT
STOCK LSD DIFFERENTIAL $581.18
Part No : MS03-27-200A
SWAY BAR, FRONT $202.42
Part No : 0000-04-5316
SWAY BAR, REAR
Part No : 0000-04-5317 $125.65
Sway bars are non adjustable.
Stock shocks, ProKit springs, Hotchkis Bars
Off the shelf yellow Konis. $750 - $800
Both ends adjustable at the top.
It rides about stock with the shocks.
The Hotchkis Bars are like the MS-R bars but
adjustable. I have read Hotchkis made the MS-R bar.
The ride changed some with the sways.
The sways are what make the MS-R package work. The spring rate increase is
small compared to what they run in STR. STR springs runs 800-700F and 500-400R range.
In hindsight, I wish I got the sport suspension package for the LSD. I have an open diff and hate it.
So did you buy an NC?
Congrats! Details and pics when you can.
I have NC LSD installation instructions from the FSM if anybody needs them.
Thanks guys...it's not a great pic, but it's all I have for now. Attachment 5445
I know you're considering STR, but the 07 allows the MSR pkg like KB did, and it seems pretty awesome. Plus, you get the option of CS w sticky tires or TCS/STR w street tires. Just saying...
Also, there is a Progress FSB on the pointy board classifieds for $75
AST 5200
/tread
5200s are only $3200?
Hi Sam. Congrats on the NC. Make sure you talk to MER about suspension and shocks. They wrote the book on the MSR package. I have the same package as the General, however I have double adjustable Sachs shocks off of the Playboy Cup cars. If you go the MSR route you won't believe the difference in the car.
Agreed. No need for double-adjustable unless you really want to get into fiddling, which I doubt Sam does.
I have old 3100s (single-adjustable) and still love them.
I still think Sam should go with the previously-enjoyed Enduras from McShane. They are comfy on the street and will service Sam well on the AX course.
Looks great! Any surprises yet?
What Bilstein's are these...can anyone tell? There are 3 flavors from what I've read...OE, Sport & HD.
Can't answer your actual question, but I can offer the useless observation that those are factory tophats and dust boots!
Here's what I'm thinking about getting -
Bilstein Sports-
http://performance.importrp.com/bils.../i-223464.aspx
Eibach Springs/Sways (Eibach=Mazdaspeed in this case) -
http://performance.importrp.com/eiba.../i-286851.aspx
I don't know that vendor but don't trust them since they can't get product descriptions correct, spelling as well.
There are no bump stops and helper springs and you shouldn't ever need them with the ProKit Spring. The NCs don't ride on the stops like the previous generations. Also, it's of popular opinion that the factory bilstiens are softer damped than the factory tokicos. However that may be a good thing for your autocrossing to allow faster slaloms. For track, heavier bars and stiffer damping work better for sweeper curves. In a slalom, the heavier bars can release too much energy suddenly causing the car to step out.
That's probably true, but those are the factory installed Billy's. The Sports and HD's are not the same.
Thanks for the vendor warning, but I did check them out on resellerratings.com
http://www.resellerratings.com/store...lacement_Parts
I have no first hand experience w/ Bilsteins on an NC so I don't know if they'll be too soft. Are the HD ones the factory installed? If so, aren't they valved the same just a tad longer shaft than the Sports? BTW, Tire Rack has the bars/springs package you want for 399 and the same shock for 105 but I don't know what shipping and taxes come to.
Wouldn't Koni's be more better than Bilstein's??
I think Miatamoto or RPM Chris tried Koni's w/ Hypercos early on but not sure. Maybe they can help.
PS. I think the Bilstein and Koni difference is that Bilstein has a lifetime warranty.
Koni's are also adjustable aren't they??
Konis have a lifetime warranty as well, and excellent customer service. Good thing, since I've had Konis I four different cars and had to return at least one shock on three of those cars.
Yeah they are adjustable making them almost 80 bucks a piece more than the Bils.
