I am getting weird tire wear. Camber is -3.5, toe is 0. Tie rods are new, bushings are new. Alignment is fresh.The inside of each front tire is wearing. The driver's inside wear more than the passenger side. Thoughts?
Stop driving in a straight line... i'd be most suspect of "alignment is fresh"...
wow, channeling jeffman, eh?
I agree that the alignment sounds off. Maybe it settled, or they didn't tighten the tie rods properly. My guess is toe. Ballasted, I assume?
If you don't have a repeat-alignment plan, I can't recommend Texas Track Works too highly. They will still give the $135 forum price for 1 yr unlimited if you ask. Maybe not to a BMW douche...
Over-inflated?
How do they smell?
Balance?
too much camber and possibly too much toe in/out.
3.5 is ALOT for a car that sees any amount of street time...
Not sure I agree totally. I run -3.3 and I get a consistent zero toe, at least on a good rack. Camber wear tends to show up more as uneven wear across the tread, not cupping.
3.5 negative will wear inside edge unless you corner hard often..............toe in will also wear inside edge.
Agreed, but toe-in will result in cupping.
I don't think its alingment related at all. I think its because the last few events you've done have all been predominantly CCW.
Let me guess - if you look at the rear tires, you're getting similar wear patterns. Am I right?
No. These are the tires I use to drive to track events. I have not autocrossed on them. My autocross tires don't last long enough to see wear.
Just has alignment checked and toe in the front is still zero.
Could this be from the camber and the inside front tire dragging when I am turning?
Like in this image.
If ^ is right, then sounds like you might have some of the typical worn out BMW bushings and rubber bits. You getting any clunking? Weird handling on broken pavement?
All bushings are new. Tie rods are new. Wheel does not vibrate like it is out of balance. Nothing is bent. No clunking.
Possible bad batch of tires? I also agree that -3.5 seems alot for street driven tires and can wear out the insides in a hurry regardless of toe..
Send the pics to the manufacturer and ask for their comments.
It has always been at -3.5 to -3.8 with zero toe.
Previous set was Hankook Evo or something. This started about a year ago. I had the same wear with the older tires so I replaced everything in front.
Car is corner balanced for Wookie driver. Alignment is all jacked up when I get out of it. Actually it does not change that much with the stiff springs.
I am at a lost. The only thing left to consider is that the lower ride height has changed the suspension geometry to point that it is now causing this.
Other item is that all my other wheels are 18x10 et25. With this set of wheels front is 18x9.5 et29.
Did you replace the "eyeball" lower control arm bushings? If so did you use OEM or stiffer aftermarket ones? I know that the OEM ones will allow the rear of the control arms to move around quite a bit under load.
It's just trying to tell you that you've owned it too long....
Eyeballs replaced with PowerFlex.
But I still like this one and don't want it to go yet.
I guess you could always increase the ride height and see what happens.
Probably jacked up geometry since its been lowered....sounds like the other variables are covered.
