my car won't start after Hallett?!
I drove my '01 up there, ran around the track(120 miles, wot) without a hitch...
drove all the way back to Mckinney(800miles for the trip).... I pulled into a CVS pharmacy...
the car won't start.
Miatas are easy to tow...
OK, my analysis(?)
the timing belt was loose and therefore replaced, and double checked with regard to TDC and it lines up. turns over, but no run...
fuel pump has been replaced after diagnosis with a jumper wire...pump noise, but no run.
Cam Angle Sensor(CAS) replaced....nothin'
Crank Angle Sensor replaced with JDM.....
help! i've been without my fix for over a week without a single cylinder firing!
jerome.
Swap maf's and check the coils and tps
